Amplifier/speaker combination system
Just wondering if anyone could give me a bit of advice - I'm looking at getting an amplifier and speakers, not really bothered about a cd player as will just use my ipod. However, I know NOTHING about hi-fi separates so could anyone recommend something in the range of £150-200.
 Not too bothered about getting a new amp as I know some of the older ones perform just as well, if not better, but don't really know what I'm looking for on ebay! If anyone has some suggestions love to hear them! Cheers
Also, can you use an amplifier for connecting to dvd/tv or would I need a receiver? Is it worth getting a subwoofer too or just speakers?
Well you're spoilt for choice on ebay, even for the modest budget you have. Can you be more specific into brands you like/music being played?
You will be able to connect your tv to the amp via RCA cable, the only real reason to get a receiver is if you're going to want surround sound at any point.ÿ
One suggestion would be a used Rotel RA04 or 05 (same as 04 with a remote) with a pair of Wharfdale Diamond 9 speakers. Very enjoyable sound.
Hi, thanks for the reply.
ÿMusic I listen to mostly is reggae, electronic, folk - erm so basically everything apart from r'n'b, garage, new hiphop etc! Haven't really got a specific brand that I'm after, open to suggestions! I'd probably just be looking at getting an amp then as can't see myself going for surround sound anytime soon.ÿÿ
You'll struggle to get that Rotel/Wharfedale combo for £150!! if you can tell me where!
Maybe look at a second hand Nad amp and Mission/Q Acoustics speakers?ÿ
Haha, yeah, I thought it was per component! Never make assumptions...
Yeah had a look at the nad c370 amp, would that be a good one to pair with the speakers? Is it better to get a amp with a higher watt output than the speakers?ÿ
If you can afford a nad with the Diamond 9 that should be OK
Cheers for the advice, becoming slightly more clearer. One last thing................are there certain cables that are worth getting to enhance sound quality?
These are comparable with interconnects of up to around £50, I think he does an Ipod connection too.
fjones101:Cheers for the advice, becoming slightly more clearer. One last thing................are there certain cables that are worth getting to enhance sound quality?
fjones101. . .I'm not sure why you've started two posts for the same subject. Anyway, go with the Wharfedale/Nad combination, the Diamonds are the best speaker [amongst the best] at that price-point.
Final question - which would be the best option with the wharfdale speakers?-
Pioneer SA520
Technics SU-A700MK3
NAD C370ÿ
fjones101:
Pioneer SA520
Technics SU-A700MK3
NAD C370
The heart says go with Pioneer but the head says Nad. I know from personal experience the old Pioneer stuff waws mustard. The Nad is good for the money, but I've never had the opportunity to compare.
