andyjm said:Google 'impedance matching of amplifier outputs' and there is a wealth of information about the advantages of using transformers in amplifiers. The negatives generally outweigh these advantages however. For a transformer to have decent LF response it needs to be big. This creates cost and weight issues, and for a stereo amp you need two of them. Transformer coupling is widely used at higher frequencies where size isn't such an issue, but at LF it is hardly used anymore - except in valve amps where there isn't much alternative.
drummerman said:andyjm said:Google 'impedance matching of amplifier outputs' and there is a wealth of information about the advantages of using transformers in amplifiers. The negatives generally outweigh these advantages however. For a transformer to have decent LF response it needs to be big. This creates cost and weight issues, and for a stereo amp you need two of them. Transformer coupling is widely used at higher frequencies where size isn't such an issue, but at LF it is hardly used anymore - except in valve amps where there isn't much alternative.
Where is transformer coupling still used widely (at higher frequencies) in Solid State?
regards
