Amp opinion
Hi (you can tell im new to this with all these post lol)
Quick opinion on what would be a better amp for me
Speaker are b&w 365
Amp choices...
Marantz PM6002
AudioLab 8000S
Cambridge Audio azur 540
I listen to alot of classic rock and indie music including as well as alot of acoutsic suff
Thank you
Do you mean B&W 685 speakers as there's no such thing as B&W 365?
With regards to the amps youve mentioned; the Audiolab would be my choice. Both the Marantz and C/A amps can sound lifeless and a bit clinical at times, more so with B&W speakers.
Another choice could be the NAD C315 integrated amp, or, if youre happy with 2nd hand items via eBay, the NAD C320BEE integrated, NAD C352 integrated, an Arcam Alpha 9 or 10 integrated or an Arcam DiVA A85 integrated (if you can find one).
All the above mentioned work very well with B&W speakers and will also work well with your music tastes.
What CDP will you be using?
Of that shortlist, the Audiolab for me; widely available for under £300 now, expandable by adding power amps in the future to it, good solid reviews to back it up too. That'd be my call.
Thanks guys
for the cd player i think ill be using either the
marantz cd5003
or the
audiolab 8000C
i did mean the 685 just a typo
Go for the full Audiolab set-up; it'll have much better synergy over the Marantz or a mix/match sysetm
I can highly recommend the QED Silver Anniversary speaker cable or the Chord Carnival Silverscreen speaker cable either matched with QED Qenex3/SilverSpiral interconnects or Chord Crimson interconnects
Have you thought what speaker stands your going to use?
I think i will,
Was planning on using the QED Revelations are the Silver Anniversary as good for cheaper??
Not really given much thought to speaker stands as of yet. will have to asess space issuse lol
Thanks you've all been extremely helpful
