Amp Jumpers. Anybody try these?
jaxwired
284
6
18,895
These are inexpensive and I'm considering trying these to replace the stock U jumpers on my NAD amp. To be honest, I don't expect the change to be noticable, but it's cheap, so why not....
Anybody out there try these or something similar?
http://www.musicdirect.com/product/72798
lazar1980
31
Hi, i dont know about particular ones but i got myself a gotham(amp jumper) and goldenjacks(attenuator) off ebay. Since it was only ~35quid and didnt have much time i plugged them both together. For the first hour or two sound was terrible but then became ok.
Only after few days things came into place and: Remote became usable, music listenable at lower volumes, much more relaxed presentation, music separation seems more obvious and deffinetly hearing details I didnt hear before.
But cant tell you is it cause of jumper or attenuators ;)
Well, hope that might give you a clue. Good luck
Regards
