JezBaker said:
Deanhartley
sorry for hijacking the thread but would you have any advice on what amp to pair monitor audio RX2's with? im looking to upgrade my amp in not that long and would love to know what amp goes really really well with the RX2's synergy wise
Hi, Thanks for buying RX2, It's an odball by todays 'slim/compact' speaker trends. However the benefits of the large 8" driver cannot really be matched dynamically by smaller drivers. You really need an amp to driver them hard and get the scale they are capable of. In my view anyone should look to spend around the same on an amp (at least), as the speakers. You need really to be looking at something like a Naim Nait5 or Rotel 1520. However, don't discount used equipment. My choice would be to go for a used Cyrus 8 integrated amp (probably around £400, check ebay). All should work well with the RX2. Hope that helps If you are looking for two-channel only, then I'd definately look down this route. Regards,
