tomlinscote said:Am going to get myself a NAS system and was wondering if there are decent alternatives to the SONOS systems, I am not too fussed about multiroom but if its there....., budget is going to be around the same price as the zone player 90 or connect as it now known, so say less than £300.
The ability to stream from the NAS and listen to internet radio are the key points plus sound quality as the NAS files will be WAV or similar (not fussed about album artwork etc as the device will be connected to the stereo not via AV and TV)
tomlinscote said:I have read on here that the Sonos kit suffers from SQ issues (jitter etc)
tomlinscote said:I have read on here that the Sonos kit suffers from SQ issues (jitter etc) hence the qn is there something with a better SQ or is the Sonos decent enough ie CD quality (with the right file type obviously )
John Duncan said:Below 300 quid, and in the absence of the much-missed Squeezebox Touch, I don't think I could see past a Sonos tbh. It's functional, the app is good, Spotify is built in, blah blah. If you're worried about ekeing out the last drop of sound quality, you can add a DAC or even the extremely cool and genius Arcam Sonlink:
(cue gasps of horror from The_LHC...)
bigboss said:Ive got 2 ZP90s (or Sonos Connect). One is plugged into my AV receiver, & the other is connected to a pair of powered speakers (Audioengine 2). Both systems are brilliant.
spockfish said:But on a more serious note: imho the Sonos has only *one* problem: no HD support. Luckily enough recently the new brand Bluesound entered the streaming party, and they do HD...
spockfish said:Just buy a second hand Squeezebox Touch
Keep in mind that wrt usability the Sonos and Squeezebox Touch are in a way better leaugue than the average DLNA-based streamer.
