Alternatives to Cyrus Stream X2?
Superaintit
100
Interesting question since you already have 2 streamer, the apple tv and airport express. May I ask why you would want another streamer but now without a dac... :?
The first thing that comes to mind when thinking of a streamer without dac is a NAS that sends over ethernet cable. (if it sent over optical or any other digital cable it would have gone through a dac, me thinks.
matt49
51
My own preference would be for a NAS drive (with suitable server/client software) piping into a DAC via USB, but that wasn't what you asked ...
If you're after a music server (without DAC) from a hi-fi manufacturer, you might consider the Simaudio Moon MiND 180D. I know a couple of people on the 'Wam who use them and are very happy. I think the price is about the same as the Cyrus. I don't know how the functions compare.
:cheers:
Matt
ifor
114
12
18,595
Yes, I can and do stream from the iMac in the study through the ATV in the sitting room to my current DAC. But can I get better quality than this with a dedicated device reading the ALAC files stored on the iMac, or NAS, if I were to get one?
ifor
114
12
18,595
:cheers:
Matt
thanks Matt. I'll have a look at it. I don't really understand why these things should be so expensive without DAC an analogue stage.
Crossie
58
Save yourself a lot of money and get a Sonos Connect ( I know it has a DAC) just use the digital out. Much more reliable than Cyrus and easy to set up and excellent control interface.
ifor
114
12
18,595
Am I right in thinking that hi res is not supported?
Superaintit
100
Yes, from what I've heard the Cyrus streamer is good, but its a lot of money for something (as far as I can tell) is no more than a Cyrus dac plus a streamer function. I think the main difference you will hear is the difference in sound signature and detail between the Cyrus and the Rdac.
That's what I heard comparing arcam Rdac and Cyrus X dac when streaming from a mac mini. The Cyrus streamer I heard on a seperate occasion. So it not 100% certainty, which you could only get by comparing with a Cyrus streamer and a Cyrus dac in your system...
EDIT: I'm assuming here you stream through the Rdac as the Cyrus cd 8 has no digital in according to specs. Furthermore: I found the Cyrus remote with the streamer not so user friendly.
Crossie
58
[/quote]
[/quote]
Just to clarify:
Stream X is a pure streamer no DAC
Stream XP is a streamer, DAC and preamp.
ifor
114
12
18,595
[/quote]
Just to clarify:
[/quote]
Yes, its just the streamer function I'm interested in, not the Cyrus DAC.
ifor
114
12
18,595
:cheers:
Matt
it's shame the dealers are so few and far between. I'd love to try this one out. It's so neat and small too.
matt49
51
It might be worth giving this chap a call. I'm told that, aside from making isolation platforms, he supplies Moon kit, and he may have a demo model he could mail to you. (I'm assuming you're in the UK.)
:cheers:
Matt
PEAYEL
19
See signature. I think that the Sonos into my Cyrus 8 DAC is just about right. As all the Sonos outputs are on all of the time I have ABC the optical, coaxial and analogue outs into the Cyrus 8 and the 8 gives a fine account of itself. I guess that you will find the same with your kit. Unless you're going for overall upgrading the Sonos will easily suffice. I have posted elsewhere on here about my thoughts on HD, and I still can't hear a difference on my home set up.
ifor
114
12
18,595
Thanks Peayel. I do intend to upgrade my DAC and amplifier at some stage. Having so little Hi Res music, and it can't be streamed from iTunes through the ATV anyway, I have no opinion at all about whether or not it is better that CD quality, but I would rather keep my options open, especially if other items are going to upgraded.
