AKG by TIËSTO
BEDROCK
59
Hello, has anyone purchased these yet and what are the views on them?
K267 TIËSTO offers an over-ear, closed-back design, with an oversized low resonance driver, providing a higher SPL, while still maintaining a matched low frequency bass response. Its user-adjustable bass boost keeps sound neutral or maximizes deeper sub-bass frequencies when prompted. With high-quality materials and superior workmanship, K267’s sound quality raises the bar for the professional DJ with the best performance without compromise. K267’s Dual Plug-In feature allows the user to attach the cable to either side for maximum comfort. In addition, each set boasts 3D-Axis folding mechanisms for optimum fitting and flat storage.
K167 TIËSTO is an over-ear, closed-back design for high comfort and maximum noise rejection. Suitable for multiple applications, from the stage to the studio, DJs and music enthusiasts will enjoy the stunning design and impressive sound quality, even in loud environments. Its 40mm driver allows for higher sound pressure levels, while its roadworthy design provides maximum reliability.
K67 TIËSTO’s on-ear design is ideal for the perfect sound on the go. They are designed for a wide range of applications from live sound to studio work. The compact design delivers convincing and powerful sound wherever necessary, even outdoors.
Check the reviews on Amazon U.S. The K167 isn't doing very well. I didn't bother with the others.
