Airport Express to DAC - optical cables - all the same?
BluePotato
29
I'm working through how my system will be set up when completed. I plan to stream from the Mac to an airport express, into a DAC - amp - speaker. I believe that's the way to do it.
Specifically regarding the optical link from the Airport to the Dac - are all optical cables as good as each other or is this more like speaker cable and interconnects where careful consideration is required?
Paul.
745
55
18,970
I couldn't tell the difference between a Chord Optichord and a £2 job. The chord was worth the £15 I paid on eBay for the build and nice aluminium bits though.
ifor
114
12
18,595
I've not compared, but I use a chip as chips £2 something 10 metre job I bought from eBay or Amazon. I didn't realise it was 10 metres long until it arrived. It's used to connect Airport Express to Arcam rDAC and the audio quality is excellent.
fr0g
445
Only difference is build. And the heavier built ones are more likely to damage the socket.
Hi BluePotato
I'll recommend using a basic fibre optic cable.
Fwiw, i use a fibre optic cable which i picked up from the local market for a £1 to transfer data from Yamaha's BD-S1900 Blu Ray player to a Chord Electronics DSP8000 AV processor.
All the best
Rick @ Musicraft
