Air Lock Banana Plugs
stevee1966
211
8
18,795
Does using 4mm plugs on the end of speaker cable give an audible difference ?
Planning to buy some QED Silver Anniversary XT cable and wondering whether it is worth the extra £20 per cable to get them terminated.
No, not worth the cash unless you're a prolific cable fiddler and need to be able to quickly 'draw'. Its another connection/solder joint in the signal path and will do nothing to improve the 'inherent sound' of whatever cable you choose.
drummerman:No, not worth the cash unless you're a prolific cable fiddler and need to be able to quickly 'draw'. Its another connection/solder joint in the signal path and will do nothing to improve the 'inherent sound' of whatever cable you choose.
I'd agree with Drummerman in that it certainly doesn't do anything to improve the quality of the signal transfer.
However, IMO it does make for a neat installation and minimises the risk of short circuits from loose wire strands. I'd suggest you invest in some decent quality plugs if you wanted to go down this route so as to minimise any signal loss at the connection. I've got the QED screw locks in the back of my amp and they are fine.
I've googled QED cable and the price for plugs from most suppliers is £4-95 each, so just a shade under £20 for 2plugs on amp end and 2 plugs on speaker end per cable.
I think the QED airlock plugs are rather overpriced, and I've heard mutterings that the airlock... isn't. I'd just go for some reasonably sturdy banana plugs, e.g. from Maplins.
