- Aug 10, 2019
- 2,556
- 4
- 0
Basically this boils down to the age old question of “all-in-one system vs budget separates”.
But first, a little back ground may help you appreciate WHERE I’m coming from:-
Several years ago, I decided it was time to replace our good old HiFi. The system in question was a Technics separates, which is now about 17 years old and benefited greatly from the addition of a pair of Mission
760 speakers shortly after.
My brief (about 6 years ago) was to replace the bulky HiFi system with something that sounded just as good but took up much less space.After narrowing the search to a Denon DM30 micro system and a Teac micro (cant remember the model), I became the proud owner of the Denon.
Disappointingly from the start, both myself and my better half, realised that the sound from the new baby was no where near the sound of the old system. Even with my trusty Missions, it failed to enthuse its audience.
BUT – we had gained a chunk of valuable house space – so whocares???
Having lived with (and little used) the DM30 for a goodwhile, it decided to break down about 5 mounts out side of warranty, and our friendly TV/HiFi repair man said it wasn’t worth repairing. Strangely I wasn’t disappointed, and took great pleasure in hitting it with a hammer and taking it to the local tip.
So, after total upheaval due to re-decoration, the living room fell silent for a while. AND we had even more space in the living room.
Yet, this summer – because its been wet and we’ve been indoors much more than normal, I’ve often thought – I could just do with some music. – Ah! – problem – no Hifi set up.
Thank goodness I had just put the dear old Technics system in the garage loft rather than flogging it to a lucky punter on EBAY. So, after a dust down, its temporarily squeezed back in the living room.
The problem is, we now don’t really have room for it.So, I have the dilemma:-
Don’t bother with any HiFi at all.
Get a Micro system so as not to take up too much space.
Sod the space issue, chuck out some furniture and get new separates.
Choice (a) isn’t really aimed at this forum.
Choice (b) must take into account the disaster with my previous micro system- even if Denon gave their best micro system away I wouldn’t take it.
Choice ( c) will take very careful negotiation with my better half, to allow a permanent separates system in the house.
Hence, (at last) my question. Is it possible for a decent (non-Denon) Micro system to
sound almost as good as a budget separates system?
If so, how much of a part do cables, connectors, speakers really make?
In an attempt to get a head start before visiting HiFi dealers, I narrowed my list of Micro systems to:-
Teac CR-H255
Onkyo CS515
NAD C715
As for the budget separates:-
Cambridge Audio Azur 340Ase
Cambridge Audio
Azur 340C
Possibly the Cambridge Audio Azur 640T
Or
NAD C315BEE
NAD C515BEE
Unsure about a suitable tuner, the NAD C445 is way over
budget.
Finally – somewhere in the middle:-
Teac Ref 300 MKIII
If possible, I’d like to stick to same the brand, other wise “my better half” will say our living room looks like a second had shop! But that’s another story. This is the main reason I’ve included the Teac Ref 300 MKIII, but I’m struggling to figure out if its an over priced psuedo-micro system or a neatly packaged, quality single brand separates system.
As for speakers, I still love my old Missions, so would they be upt to the job of any of the above systems? Or would they be greatly enhanced by having a set of M-S 902i’s or similar?
Apologies for the long read, thank you for getting this far!
Thanks in anticipation.
Teac CR-H255
Onkyo CS515
NAD C715
Cambridge Audio
Azur 340C
Or
NAD C315BEE
NAD C515BEE
budget.
Teac Ref 300 MKIII
