AE Compact 1 BARGAIN!!!
The_Lhc
1,176
scene said:
The_Lhc said:
scene said:
great spot.
Difficult to miss when the manufacturer is mentioning it on Twitter...
See, that's the problem I have with not being in the Twitterati...
It does have it's uses and you can giggle like a girlie when they reply to you and you feel all special as if you've just spoken to someone famous or something.
I'm told...
John Duncan
2,033
27
19,720
The_Lhc said:
scene said:
The_Lhc said:
scene said:
great spot.
I'm told...
#unfollow...
John Duncan
2,033
27
19,720
bigboss said:
How's your Mumbai trip going John?
Badly. Have spent last 24 hours in my hotel room #bitsick
Luckiy, the view is quite good:
psurquhart
318
Sorry to bring this topic back into relevance and sorry to hear about your Mumbai illness and the rest of your in house banter.
However - how much were these speakers originally ? And would they make a decent rear surround set up bearing in mind I have PMC GB1's and PMC DB1c as fronts ? Would they intergrate well ? Need to replace my broken Mission 752 Freedom rears running through a Sony DA5400es av amp ?
Any advice ?
Or any advice on a cheap alternative that would intergrate well with my PMC's ?
John Duncan
2,033
27
19,720
150 quid
psurquhart said:
And would they make a decent rear surround set up bearing in mind I have PMC GB1's and PMC DB1c as fronts ? Would they integrate well ? Need to replace my broken Mission 752 Freedom rears running through a Sony DA5400es av amp ?
For 100 quid, you're not going to find much better, at a guess. I'd suggest Diamond 9.1s but cheapest they're going for is 120, and they're a bit chunkier which may be an issue for you. You might lose a *bit* of scale compared to the Missions, but not a huge amount, bearing in mind it's for the rears.
psurquhart
318
John Duncan said:
150 quid
Thanks John.
One final question - I would be wall mounting the rears and I am liking the look of the AE1's - I also noticed that they come complete with wall brackets so it's pretty much the complete package. However, do you know if the Diamond 9.1s would also come complete with brackets ?
