- Aug 10, 2019
- 2,556
- 5
- 0
Hi, any advice on a system upgrade would be great.
Im currently running, B&W 601 S1 speakers with a Pioneer RMX9 CDJ all in one system. Also occasionally using an old Sony Mini HiFi system (MHC-RG270) for a bit of extra volume, bass or a bit of (like) surround sound when needed.
I was thinking of getting a powered subwoofer so I could reduce the required bass output of the various speakers so they are able to focus on mid's etc. Either that or looking to buy an upgraded amp or speakers. But i would still like to keep the function of the Pioneer set. So;
a) Would i loose any conciderable quality running a second amp (and the B&W speakers from said amp), from the phono output on the Pioneer unit? I'm currently running the sony from there but the quality of the sony is quite average there anyway.
b) Generally what would you recomend? I'm quite new to audio and usually rely on reviews and, to be honest, bargin hunting (managed to get the above set for under £200, sorry to brag). So any recommendations will be gratefully recieved.
I could probably strech to about £300-400, but would be looking to buy from ebay (or like), so please think in second hand prices.
FYI - I'm a 'general' music user, very novice DJ, though looking to improve. System is occasionally used for movies, gaming etc.
Music taste - Dance, D&B, Hip-hop (not sure if that helps)
Thanks in advance for any help and advice,
Sam
Sam
