Advice Please - An Amp to Partner Marantz CD-63 Ki Sig & Tannoy Revolution R3 Speakers - 4m by 6m Room
John Duncan
2,031
15
19,695
Marantz PM7001 (the KI is probably in budget also). Creek Evo direct from the manufacturer. Second-hand Primare A20 or i21. Rotel RA-06. Exposure 2010.
John Duncan
2,031
15
19,695
And of all of those, my preference would be the PM7001KI or Primare i21 - both of which ought to be easy to find and audition, and then you can either buy the Marantz new or the Primare second hand. If I wasn't such a big fan of Primare aesthetics, I'd just say get the Marantz, it's very good.
Thaiman
360
Fast CD player with smooth pair of speakers seeking partner?
Enter Musical Fidelity A3 or A300 (£350, £400 - 2nd hand)
lovely amp that will work wonder with the gears you already have. If you after a new amp then like JD said, the PM7001 should be a fine match.
Rotel RA-04 @ £250.00 (if new). The MF A3 or A300 as suggested by Thaiman are excellent.
ASK THE COMMUNITY
