Advice on yamaha sound bar ysp1100
I am connecting to sky HD by optical cable, is there any way of splitting this cable so I can connect to a dvd player through this single connection (or are there other ways of connecting just as good?)
Also will it make a difference to upgrade the optical cable?
daveh75
johnb1966:
I am connecting to sky HD by optical cable, is there any way of splitting this cable so I can connect to a dvd player through this single connection (or are there other ways of connecting just as good?) I'm a bit confused here...Why would you need/want to split the optical connection.
According to the Yamaha YSP-1100 tech specs, it has two optical, and one coaxial digital input, so you should be able to connect Sky HD and DVD player to the soundbar...
A contentious issue, but no, imo.
i need to check - was sure mine had only one? thanks will check now
