A admin_exported New member Aug 10, 2019 2,556 5 0 Oct 16, 2008 #1 A bit confused on the Subwoofer Setting i have a Yamaha RX-V363 Amp, the setting on the Subwoofer is set to reverse is that right or shall i change it to normal. Any help would be appreciated Thanks.
A Anonymous Guest Oct 16, 2008 #2 I guess you are talking about the phase setting. Change it to normal.
B Big Chris New member Apr 3, 2008 400 0 0 Oct 16, 2008 #3 Try normal first, but if you find you prefer the sound while it's reversed then that's not a problem. Stick with your favourite.
