- Aug 10, 2019
- 2,556
- 4
- 0
Was hoping to gain some advice on my search for a good match of floorstanders for my Bel Canto system.
I've had Proac Studio 110s hooked up to my Bel Canto S300 power amp for some time now and was really enjoying the results. However after moving and gaining a larger living room I'm lusting after some floorstanders. My room has oak floors and is pretty hard throughout aside from a thick pile rug and sofa etc, the space is about 6m x 6m. I listen to a lot of alternative, electronica, dance as well as rock, jazz, ambient, folk. The amp rated at 150w per channel at 8ohms grips the speakers really well, bass articulation is excellent though can get a bit boomy, mid range smooth, high frequencies can be a bit harsh/ shouty. I'm guessing the boomy bass and shouty highs could well be the room acoustics.
I'm looking for a more relaxed and authoratitive sound and a bit more bass. Most listening quite low except on Friday nights.
My budget is up to £1100 and I'm predomininantly looking at second hand, ex dem and online bargains.
Here's what has caught my eye so far:
PMC FB1+
B&W N804
Epos ES30
Focal 816wse
Focal 826v
Proac D15
Wharfdale Opus 1
KEF XQ30
ATC SCM35
A far reaching selection, hence hoping to narrow my search with some advice from the forum.
Many thanks,
PMC FB1+
B&W N804
Epos ES30
Focal 816wse
Focal 826v
Proac D15
Wharfdale Opus 1
KEF XQ30
ATC SCM35
Many thanks,
