Any advice on building a first system on a budget of £800 - £1000 would be useful.
I need a DAC, cabling, a amp and speakers. Any suggestions would be much appreciated? The system will be played off a Computer and the DAC needs a USB option. I was considering mainly the Beresford tc-7D20 but did also consider a V-dac. The Amp and the speakers, I really do not know.
The system will be for a small room, musically I would like the system to sound 'fun.' I listen to rock/pop, indie rock, classical, jazz, and acoustic music. I really dont care about bass or the abilty for good sound at anything above a 'normal' listening volume. The system would also ideally be easy too set up. Finally, I am considering buying second hand, thinking that then I would be able to trial and resell equipment would this be advisable? If so where is a good place to look for second hand gear?
Thanks in advance,
Will
Thanks in advance,
Will
