Hello!
About me:
Before I start, may I just explain that my understanding of audio technology is pretty limited. I’ve taught myself the basics but, as this is for a one-off project rather than the beginnings of a hobby, I don’t know much more.
About my project:
For my school resistant-materials project, I’ve decided to build an iPod dock. It will need to amplify and play music. Rather than rely on battery power, it will plug into the wall and the audio input will be a 3.5mm jack. The exterior dimensions will be 400mm x 200mm x 200mm whilst the interior dimensions of the speaker enclosure (a simple non-ported design) will be 350mm x 150mm x 120mm. These dimensions are however not final – I can change my designs if need be. The whole product will be made from Baltic Birch Plywood. The final product needn’t be incredibly loud but I would like the sound quality to be quite good. I have a budget of £100 for audio componentry.
Question:
What audio componentry would you recommend I use in this project? As I understand it, I need the following:
A compact amplifier that will accept a 3.5mm audio jack as an input
A pair of full range 4” coaxial drivers
OR:
A compact crossover
A pair of 4” woofers
A pair of 1” tweeters
Are these the components I’ll need? If so then what specific parts would you recommend? Any other advice on the project would be greatly appreciated!
Thank you all in advance,
Isaac
About me:
About my project:
Question:
OR:
A compact crossover
Isaac
