Hi, What started out as a new fridge has turned into a full-blown extension and new kitchen in our house. I figure it is a good idea to put speaker cable into the wall and wall mount stereo speakers up high on the wall. The kitchen is 6m x 6m and will be subject to all the normal kitchen stuff - noise, heat, screaming kids. The new system will be used predominantly for radio (2, 4 and fivelive mostly)and iPod. Right now we have a Denon M30 and the matching speakers plonked on the counter of the kitchen which sounds fine, but the speakers are kinda bulky for wall mounting.
So the help I'm looking for is as follows:
* what system(s), speakers and speaker cable should I be considering? I don't want to go crazy in terms of budget.
* I'm planning to have the speakers in two corners of the room, high on the same wall - is this "correct"?
* any tips or tricks about installation? The builders will put in the cable but will look for my advice
* what about racking or shelving for the player itself? I want to avoid putting it on the work surface if I can.
* I might fit a little TV on the wall, any value in trying to run the sound for this through the stereo speakers - I don't want to put a full setup with amp in the kitchen - better to keep it simple and just run the sound out of the TV? Will be just used for the kids.
Thanks much in advance, any help appreciated!
DjP
DjP
