Adding pictures to your posts
MattSPL
19
Does anybody know how you add pictures to your posts?
It came up with a message saying i need permission from moderator?
Matt
Hi Matt. It should be a simple case of right clicking on the image>Copy (CTRL+C), and then in your reply box just right click>Paste (CTRL+V).
Ok thanks for the help lads
Just out of interest, I've always assumed that my posts are spaced in the way I type them in (which means carriage return at the end of a paragraph and not the HTML equivalent). If this is not the case, do all of my posts appear as one large block of text?
Andrew Everard:Actually, you have to have the picture hosted somewhere, and then you can link to it.
Just managed it thanks
Andrew Everard:Not a clue, I'm afraid...
I'll rephrase, does this post appear as one large line or ongoing block of text?
Or, as I have inserted a new line here...
and here...
...is it spaced out in four separate lines?!
Yep it looks fine record spot. All the line breaks and paragraph's are there just how you typed it. 🙂
If you write anything on your Bio though, you will have to use HTML code for your layout.
