AJ20011 said:
their designs are very similar to the Scanspeak equivalents, but at Vifa/SEAS prices. (SB supply drivers to AVI, BTW).
Not sure where you get this idea from. Seas is very comperable to ScanSpeak, in terms of price, across the various ranges. Vifa is indeed slightly cheaper (they are now owned by ScanSpeak).
You will find these drivers in great speakers all over the world, particularly from British manufacturers. ProAc use ScanSpeak tweeters on the D18 and D28, for example. The much-acclaimed tweeter on the PMC DB1i is made by Seas (and not even their top range).
Both Seas and ScanSpeak make a wide variety of different styles of drivers, so it is hard to generalise about their character. But in general, ScanSpeak drivers - especially their sliced paper cones - put out a lot of bass for their size and have sweet midrange abilities that tend to emerge with a lot of power. Seas drivers tend to be more about transparency. Their top-line Excel series offers two different styles of cones: a magnesium version, which is not very efficient and harder to cross over, but incredibly natural and accurate, and a paper cone version treated with a damping coating, which is a little softer but more dynamic (closer to 90db/1 watt sensitivity). And still very acurate.
Both companies make fabulous dome tweeters, in several configurations and materials.
If you are designing speakers, I highly recommend you read every word on Troels Gravesen's site. You'll learn a lot about these and other drivers. He also knows more about crossovers than just about anyone who publishes online - most important lesson from his site is, NEVER think you can design a crossover with calculations and/or software. It's much harder than you think and Troels really explains why. He has plans for well-tested crossovers built from a variety of drivers so it's a great place to start if you want to build a pair of speakers but you don't have a test bench.
And in case you are wondering...yes, you can build insanely good speakers at home. I have a pair of the aforementioned PMC DB1i's. They were 985 GBP. They contain two Seas tweeters and two Vifa midbasses that currently retail, in total, for about US$140 (which means a company like PMC pays a lot less). The speakers contain a few quid worth of wood and some very basic crossover components (they also sound great...love my PMCs in the office with my old Nait 5).
This means that, if you were to spend the same cash on really top drivers and some really good crossover components, arm yourself with a tried-and-tested design, and either get good at cutting wood or find a good carpenter, that you could build a set of speakers that you would need to spend thousands to buy (in fact, it could be still better, since no commerical concern could afford to slurge on the kind of capacitor, say, that you could do, since you are only building two speakers and not hundreds).
But if you pick out nice drivers, build a box with software, build a crossover with software, and build it, do not expect good results. It might sound okay but not true high-end. You must find a crossover design that is matched to specific drivers and baffle size, and not change anything!
Good luck...and watch out. You are starting a new and obsessive life with VERY LOW WAF.
Kevin
