A/V amp on a budget
cheyworth
145
My brother is looking to make the change to A/V and is looking to start with an amp.
He currently has a Marantz PM-66SE and wants an amp that will be as good or better for stereo music.
Budget is limited so second hand would be best? He has a PS3 so will want HD audio when he gets some BluRay.
Any ideas?
Chris
The sony 800 fanastic value you should be able to get one from around £279 online.
Try Richer Sounds. The SONY STRDG820 can be had for £230. Don't forget to allow some money for cables.
However if you want an AV amp that is going to better than the marantz amp for music you will need to spend considerably more. I hate to put a figure on it but you wont be getting much change from £1000 I wouldn't have thought.
