A dedicated phono stage?
gbhsi1
237
I currently use the built in phono in my intergrated amp for my turntable. Would I reap more benefits from buying say a 'Project phono SE'?
With a system of the quality of yours I would aim higher than the Pro-ject SE. Maybe look at Trichord Dino territory.
Trichord Dino is kind of pricey. I can get the Pro-ject SE for about £60...so would that not make a difference to the built in phono in my roksan? I would love to get the dino but too much for me right now. I have spent a hell of a lot for my current system already 🙂
I have never owned a Roksan amp so can't say really. I imagine there wouldn't be a great deal of difference, no as the built-in stage should be decent.
Hi gbhsi1,
Just to add my experience, I would concur.
The phono amp in the Roksan is very good. I tried the Phono Box as I had one utilised in my old system with Pioneer amp. Here it did make a noticeable difference but when I tried it with the Roksan it made no difference. I did manage to get hold of a Trichord Dino to use in my current system and tried it with the Roksan amp - result - Excellent.
However, as you say there is a great difference in price.
gbhsi1:Hi, I currently use the built in phono in my intergrated amp for my turntable. Would I reap more benefits from buying say a 'Project phono SE'?
Last year I asked a similar question. The fact that Roksan, along with Arcam produce some of the best built-in phono stages is kinda tricky, unless you're prepared to throw a huge bag of sheckles in the retailers direction.
Personally, I would spend my money elsewhere, like an improved cartridge, better cabling. Hey, what do I know?
I wouldn`t bother. If you had an amp with no phone stage then yes it would of course be worth your while but if you already have a built in phono then I wouldn`t consider upgrading unless you are thinking of spending quite a bit more to be honest. I know it`s hard sometimes to resist an upgrade but I`d try to hold out until a later date with this one if I were you.
Check out the thread in this forum called, "Are phono stages on mid-priced integrated amps any good?"
I compared the on-board phono stage on my Kandy K2 with my Gram Amp Communicator and found little difference.
All very valid points. I think I will save my money and when I can afford it, get the Dino Trichord 🙂
Hi, I've got Roksan's KandyK2 amp and Rega P3 turntable. Roksan's got an integrated phono stage, but after adding simple Cambridge audio Azur 640P phono amp to my setup I finally began enjoying my vynils! It does make a difference - the sound scene opens up, sound stage becomes alive. For me it made a difference. I'd recommend borrowing one from your local shop and trying it out.
Roksan Kandy K2 amp, Rega P3 turntable, FocalJMlab 816V speakers, Ecosse the Conductor CA1, Ecosse CS2.3 speaker cable
I've got the PoJect Phono SE. Bought it about a year ago and have it plumbed into my Cyrus setup. It's a fine middle of the range turntable, and like anything else hi-fi the law of diminishing returns will apply, i.e quality improves linearly while price increases exponentially.
It's fine for me reliving my mis-spent "yoof" listening to 70s and 80s heavy metal, but serious vinyl buffs would almost certainly find fault.
When I bought it I went "one step up" on the Ortofon cartridge (it's a black one but that's about all I remember). Cost me about 20 quid extra.
The only criticsms I have of the ProJect is that the unit comes with hard wired in phono leads, which look a bit on the Currys side of the price / quality balance (I would have like to use decent interconnects like Chord Chameleons) and the volume isn't as high as the rest of the line inputs, so I have to adjust the volume (thank heavens for the remote, eh?).
But I have to ask, if you have a phono stage in your amplifier, and it's working okay, why bother?
At first when I didn' t have a phono stage, I thought it was enough with the Roksan' s built in one. Yet, when I tried out the dedicated phone stage of Cambridge Audio (simple, but highly recommended by the WHF, by the way 🙂 I really heard the difference. It does pay off to invest extra 120 EUR (so much it cost me to get in Germany, as UK e-shops do not ship outside the UK).
I've just upgraded from the Pro-Ject to the MF XLPS V8. The difference is immense. I've got an old Kenwood KD8030 turntable with Ortofon Samba cartidge. I've listened to a lot of my old vinyl since upgrading, and the MF is just digging out a load of detail that wasn't there previously. I would agree with the comment earlier about borrowing one from your local hi-fi dealer. Any dealer worth their salt will lend you the gear. If you're anywhere near Manchester I would recommend Audio T, I've used them for a couple of years now and have never had a bad experience.
