I am currently looking at home cinema options. I have the option of a 7.1 set up over a 5.1 setup. When playing a disc that is 5.1 using a 7.1 set up, does the amp (Denon 2310) use all 7 speakers? Or are the extra 2 speakers in a 7.1 set up redundant unless playing a 7.1 disc?
If 7 speakers are used with a 5.1 disc, I assume it will result in a better surround sound experience?
I have the option of using CM1's with my CM7's as the rears vs. B&W M1's. If 7.1 is the way forward, I will use the M1's as my rear channels (x4), if 5.1 is the way forward I will use the CM1's.
Any comments are much appreciated
