4 OR 6 OHM
Just after a bit of advice. Do i use the 4 or 6 ohm setting on my onkyo 606 to power my MS904's? or does it not matter?
Thanks in advance.
904s are 8ohm nominal impedance, so the 6ohm setting will be fine, although with these speakers it really doesn't matter which setting you use.
Thanks, i'll leave things as they are then......untill i upgrade
