a few questions re 3d viewing:
1. which is newer Samsung ps50c680 or c6900 and which is best?
2. can I use my 18 month old PS3 as 3d blu ray player instead of purchasing new player and how would I upgrade PS3 if so?
3. can anyone recommend better tv or wait for new 2011 models?
Many thanks
3937edwards
53
i have the samsung ps50c7000 this is the latest plasma and very thin like led all be it heavyeryes you can use your ps3 you should of had a upgrade to your ps3 via the internet if connected this also makes it 3d ready to play 3d films
The 680 is newer than the 6900, but the later is thinner (37mm against 71mm) nicer aesthetics IMO(carbon grey 6900, black-blue 680) and the 6900 is the higher spec'n TV.
Yes you can use your PS3, although it does not do full HD 3D and HD audio at the same time, it's limited by it's 1.3 HDMI.
If your thinking plasma only, the samsung PS50C7000 adds a black filter for around £200 to the 6900, there is the LG PX990 and the panasonic GT/VT range that's a little more expensive.
Only you can decided whether the new 2011 TVs are worth hanging out for, they will add, lighter Bluetooth glasses, thinner frames and possibly less cross talk, but they will undoubtedly be more expensive.
Clare Newsome
1,657
Every manufacturer we've spoken to is claiming big advances for their second generation of 3D sets - and says they'll sell them at @the same price as last year's models.
For example, Panasonic claims this year's GT30s will offer same spec as last year's VT20 sets, and in fact maybe even better, as they have a better panel and advanced processing....
Let's see when the test models appear! We've had our first 2011 model in - the new Samsung D8000; review due in our April issue, on sale early March.
They my well have the same RRP as 2010 models, but what I meant to say ( not very clearly I concede) is that the 2010 models are now being discounted to
make way for the new ranges, so you will have to in effect spend more money for the newer models.
Clare Newsome
1,657
Absolutely - some great deals to be had.
But if you can spend a little more and get a second-generation set with comparatively step-up performance, it's definitely worth considering, IMO
Yeh I agree totally, I will probably have a look myself in 3-4 months time (he says with a week old TV).
Hi.
thanks everyone for the helpful information. I will check out the differences in spec.
When will all of the latest models be released, by end of April?
ot sure I can wait that long, not known for my patience, especially when it comes to buying new tech
strapped for cash
417
Clare Newsome:Panasonic claims this year's GT30s will offer same spec as last year's VT20 sets, and in fact maybe even better, as they have a better panel and advanced processing....
Hopefully that doesn't include floating blacks!
I'm intrigued to see how this year's Panasonics perform. I wish they'd incorporate more subtle motion processing, though. 200, 400 and 600Hz IFC options would be a welcome addition.
3937edwards
53
hi markjaspi i have the c7000 plasma out of a matter of interest could you tell me what you have your cell light contrast brightness etc set at as i am still experiementing at the moment to try and get the best possible picture if you dont mind
Settings are as follows:
Game mode on.
Standard :
Cell 15
Contrast 84
Brightness 57
Sharpness 10 to 15 not made my mind up on that yet
Colour 50
Tint 50/50
Everytiing in advanced off except
Colour space : custom
Red 59 0 5
Green 27 26 0
Blue 0 0 66
Yellow 47 39 4
Cyan 29 36 53
Magenta 56 0 56
White balance
24
35
24
38
Picture options
Warm2
DNF off
MPEG NF off
Film mode Auto2
Sharpness goes down to 0 for blu ray, these settings offer the most realistic colours, hope it helps.
