- May 20, 2009
- 67
- 0
- 0
John Duncan said:No. What are you trying to connect together?
mattytun1514 said:John Duncan said:No. What are you trying to connect together?
Hi remember I purchased the "Ruark Audio MR1" speakers and I had to borrow a 3.5mm jack cable now my friend needs it back so I need to get a 3.5mm jack cable but just for interest was wondering if you can connect "Ruark Audio MR1"to laptop with USB
The_Lhc said:mattytun1514 said:John Duncan said:No. What are you trying to connect together?
No, you can't. USB is a digital connection, 3.5mm jack is analogue, so you'd need a DAC between the two.
John Duncan said:mattytun1514 said:John Duncan said:No. What are you trying to connect together?
Oh yes. Did you try to connect the laptop via Bluetooth in the end?
John Duncan said:OK must have missed it. If they're working via Bluetooth, I'd forget about cables altogether for now 🙂
