I thought i would find out what 2nd systems were around - i believe as these are often a mix of old kit and some bargains they can be actually the most fun to play around with. With a main system you tend to look for end sound quality - my 2nd system is in a small cellar which works as a pc desk space and some storage. Sound quality is really not as important but my system there comprises. Source - PC only - just an output from the soundcard Amp - Little Dot III as preamp with a NAD C320BEE used as a power amp Speakers - Epos M5 Other - Chord Silverscreen and Soundstyle Z2 stands This is a mix of old replaced kit from the last 5 years or so. The Epos M5's i really like which i picked up for £175 new when the M5i came out and is probably my biggest bargain buy. The NAD was under £100 off ebay and in good condition. The Little Dot III was used as my headphone amp for quite a while when my boy was younger and noise levels had to be kept low. Now it works for headphone use in the cellar and as a preamp softening the PC / NAD sound. Actually given there is no DAC and the source isnt anything special at all, it does rather well.
