manicm said:...and he contradicts himself. In one breath he says 'It's true that 16 bit linear PCM audio does not quite cover the entire theoretical dynamic range of the human ear in ideal conditions' and in another he says '16 bits is enough to span the real hearing range with room to spare' Taking into account the noise floor of the room you are in.
He then mentions 'It's true enough that a properly encoded Ogg file (or MP3, or AAC file) will be indistinguishable from the original at a moderate bitrate.' But then conveniently doesn't care to state the bitrate threshold at which distinction gets thrown out the window.
And then he spits out the clearly dog's proverbial:
'The easiest fix isn't digital. The most dramatic possible fidelty improvement comes from a good pair of headphones. Over-ear, in ear, open or closed, it doesn't much matter. They don't even need to be expensive, though expensive headphones can be worth the money.' And just what exactly is your problem with that?
And this one takes the cake - I am clueless when he says 'Lossless formats like FLAC avoid any possibility of damaging audio fidelity [18] with a poor quality lossy encoder, or even by a good lossy encoder used incorrectly.' I give up. which village is missing a v.i.p.? anyone?
So nevermind 24/192, 128k MP3 is good enough with a good pair of headphones. I have nothing further for the defendant your honour. where do you get 128 from? as you just said, he hasn't mentioned a bit rate.
manicm said:So nevermind 24/192, 128k MP3 is good enough with a good pair of headphones. I have nothing further for the defendant your honour.
drummerman said:No idea. To my ageing but sizeable ears even spotify premium sounds just fine these days
regards
SteveR750 said:It's an interesting article, though;
SteveR750 said:Mind you, I suspect that the good 24/96 tracks that I own are more to the remastering than the change in resolution
the record spot said:manicm said:So nevermind 24/192, 128k MP3 is good enough with a good pair of headphones. I have nothing further for the defendant your honour.
He has a point. To some degree anyway. Some of the greatest enjoyment I've had of late is with my 32Gb Touch, using either high bitrate Spotify Premium, or WAV files and with some Sennheiser CX300-II buds.
As for recording quality, I've no doubts that a good recording at 128kbps is a significantly better experience - and a more honest one - than a corresponding duffer at hi-res. By and of itself, hi-resolution is no guarantee of a great musical experience; as ever, that's down to the skill of the produced and the mastering engineer.
BenLaw said:Interesting article Craig, thanksI will have a full read when I get some time. Have you experimented much yourself with 24/96 / 24/192 and what are your thoughts?
Craig M. said:manicm said:...and he contradicts himself. In one breath he says 'It's true that 16 bit linear PCM audio does not quite cover the entire theoretical dynamic range of the human ear in ideal conditions' and in another he says '16 bits is enough to span the real hearing range with room to spare' Taking into account the noise floor of the room you are in. What the hell??
'The easiest fix isn't digital. The most dramatic possible fidelty improvement comes from a good pair of headphones. Over-ear, in ear, open or closed, it doesn't much matter. They don't even need to be expensive, though expensive headphones can be worth the money.' And just what exactly is your problem with that? Everything
And this one takes the cake - I am clueless when he says 'Lossless formats like FLAC avoid any possibility of damaging audio fidelity [18] with a poor quality lossy encoder, or even by a good lossy encoder used incorrectly.' I give up. which village is missing a v.i.p.? anyone? I would like to ask the author the very same question
So nevermind 24/192, 128k MP3 is good enough with a good pair of headphones. I have nothing further for the defendant your honour. where do you get 128 from? as you just said, he hasn't mentioned a bit rate. I take responsibility for filling in the blanks which the author conveniently left out
Craig M. said:drummerman said:No idea. To my ageing but sizeable ears even spotify premium sounds just fine these days
regards
does premium have a higher bit rate than the free one? i'm not impressed by the free spotify in terms of sound quality, but i send it over airfoil so not sure if that has a detrimental effect.
Craig M. said:i sometimes feel as though posters here don't want to know this sort of thing.
CnoEvil said:JD is now deciding whether to take Valium or Red Bull! :shifty:
FrankHarveyHiFi said:Craig M. said:i sometimes feel as though posters here don't want to know this sort of thing.
There are posters that want to know this, but they tend to be on the forum that posted this up this morning![]()
:rofl:CnoEvil said:JD is now deciding whether to take Valium or Red Bull! :shifty:
BenLaw said:Yes, it goes up to 320 for premium, although not all tracks are at the higher resolution, and it doesn't tell you which! Since upgrading to premium I've done no comparisons v CDs I own, but I think it's great for listening to new music, even straight from the ZP90.
Craig M. said:BenLaw said:Yes, it goes up to 320 for premium, although not all tracks are at the higher resolution, and it doesn't tell you which! Since upgrading to premium I've done no comparisons v CDs I own, but I think it's great for listening to new music, even straight from the ZP90.
thanks, my girlfriend uses it more than me - i'll see if i can get her to pay for it.![]()
manicm said:Craig M. said:manicm said:...and he contradicts himself. In one breath he says 'It's true that 16 bit linear PCM audio does not quite cover the entire theoretical dynamic range of the human ear in ideal conditions' and in another he says '16 bits is enough to span the real hearing range with room to spare' Taking into account the noise floor of the room you are in. What the hell??
My responses are underlined. Craig, all in good spirit![]()
