Re: ADDING A SECOND I POD TO EXISTING I TUNES LIBRARY
It's easy to add a second iPod to iTunes - when you plug it into your PC, you can give it an identity, and set up a specific profile for that player - ie choose exactly which tunes from your library you copy over. Easiest way to do this is to create a playlist(s) from your existing library that contains all the songs you want on the second 'Pod.
