100hkz
cse
97
Does 100hkz make any difference on the panasonic 32 inch range. I don't know which set to buy, either 32LXD70, LMD70 or LZD80. Help???
Andrew Everard
1,878
100Hz I think!
100Hz lets the TV draw each picture more times per second - I've never seen the mere presence of 100Hz capability as a cause for recommendation over a set without this facility, and there are other factors with a much greater bearing on picture quality.
It's the numbers game again, you see..
Clare Newsome
1,657
Indeed - in fact some people find 100hz processing makes them feel quite ill! (Which is why you can switch it off on a lot of sets).
Best to have a decent all-round set than get obsessed with its stats.....
cse
97
Thanks I'm trying to chose between 3 panasonc sets 32LMD70, 32LXD70,32LZD80 and am getting confused. I will watching on Freeview, enjoy sport and don't watch DVD's.. Whayt do you recommend?
